| | | Forums66 Topics128,165 Posts1,057,086 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 3 Apprentice | | Apprentice Joined: Jul 2006 Posts: 3 | Have 1955 Chevy truck V-8, 265 Gas motor. Motor has pipe in it that goes through the block and inside the V shape between the heads, on top of the block- a cylinder attaches to the pipe. THe machine shop broke this thing and I need another one. Checker, AutoZone and Carquest don't know what it is. Harmon's and LMC Truck do not have it in their catalogs. What is it's name and any idea where I can get one ? -Engine is for a 1962 Chevy C-20. -John [email protected]
John Powers
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | John, Are you talking about the oil fill tube that fits into the intake manifold? It has a cap...it is where you add oil to the engine. This link shows a picture of the engine. http://chevy.tocmp.com/1955truck2shop/55ctsm0643.htm Stuart | | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | ya i think it is the oil filler tube
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That's what it sounds like to me. What I want to know is how did they break it? The machine shop should find you a replacement at no charge, since they broke it. Gonna have to comb the salvage yards and swap meets to find a new one. Can you post a pic so we can see how it's broken? Maybe it can be repaired.
Bill Burmeister | | | | | Joined: Jul 2003 Posts: 31 Junior Member | | Junior Member Joined: Jul 2003 Posts: 31 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sounds like John's talking about the primitive PCV tube [road draft tube] at the back of the block, the oil filler is in the intake, not the block
the question is what the heck ya doin putting a 55 265 in a 62 truck? the 265 is inferior to the 283, and there should be 283's available around you, which would be the correct engine for yer 62
Bill | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy John 62 C-20, firstly I hate to be the one to tell you but a 265 and even up to 57 283s have no provisions cast into the block for engine side mounts, so either you don't have what you think you have or it's next to useless to you. As for the part your looking for I believe that what you describe is the oil/fume separater that is held into the block by a slight press fit and one support strap that had a 1/4" screw in it, hope that helps. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Besides that, since you're not putting in a correct engine anyway, you can build a 350 for less than a 265.
