4 members (54farmtruck, klhansen, Rich'sToys, Southerntruck), 346 guests, and 3 robots.
Topics128,167
Posts1,057,096
Members48,463
Apprentice
Apprentice
Have 1955 Chevy truck V-8, 265 Gas motor.
Motor has pipe in it that goes through the block and inside the V shape between the heads, on top of the block- a cylinder attaches to the pipe. THe machine shop broke this thing and I need another one. Checker, AutoZone and Carquest don't know what it is. Harmon's and LMC Truck do not have it in their catalogs. What is it's name and any idea where I can get one ?
-Engine is for a 1962 Chevy C-20.
-John
[email protected]
John Powers
John,
Are you talking about the oil fill tube that fits into the intake manifold? It has a cap...it is where you add oil to the engine.
This link shows a picture of the engine.
http://chevy.tocmp.com/1955truck2shop/55ctsm0643.htm
Stuart
ya i think it is the oil filler tube
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
That's what it sounds like to me. What I want to know is how did they break it? The machine shop should find you a replacement at no charge, since they broke it. Gonna have to comb the salvage yards and swap meets to find a new one. Can you post a pic so we can see how it's broken? Maybe it can be repaired.
Bill Burmeister
Junior Member
Junior Member
sounds like John's talking about the primitive PCV tube [road draft tube] at the back of the block, the oil filler is in the intake, not the block
the question is what the heck ya doin putting a 55 265 in a 62 truck? the 265 is inferior to the 283, and there should be 283's available around you, which would be the correct engine for yer 62
3B Offline
Hy John 62 C-20, firstly I hate to be the one to tell you but a 265 and even up to 57 283s have no provisions cast into the block for engine side mounts, so either you don't have what you think you have or it's next to useless to you. As for the part your looking for I believe that what you describe is the oil/fume separater that is held into the block by a slight press fit and one support strap that had a 1/4" screw in it, hope that helps.
Besides that, since you're not putting in a correct engine anyway, you can build a 350 for less than a 265.
Bill Burmeister
