4 members (Otto Skorzeny, Hanks custodian, 32Fordpuchoptop, Gdads51), 166 guests, and 2 robots.
Topics128,047
Posts1,055,532
Members48,424
#216248 09/23/2006 4:47 PM
I'm about to make my own 5/16 fuel lines from tank to pump to filter to carbs and would like to know if there is a type of Stainless that will NOT flare with the flaring tool I can check out from the Auto Zone?
#216249 09/24/2006 3:28 AM
I am no expert but for stainless you need a good quality tool. It has to do with the shape or the forging quality or how much it is machined or not. In other words if the cone is not good quality shape (smoothness too) it will crack the metal.
You may not need the best but don't buy the cheap one.
1946 Chevy Half Ton
('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS)
1976 Margay Panther X, MC91B
#216250 09/24/2006 4:55 AM
You should be fine flaring SS with a good quality flaring tool. It should be even easier if you only do a single flare. (probbly fine for fuel lines) A double flare (a must for brake lines) in 5/16 will take a good tool and a bit of practice.
Read the tech tips / instructions at Inline Tube.
1952 Chevrolet 3800 pickup
---All pictures---
#216251 09/26/2006 3:07 PM
I've got some stainless that I tried to flare with my hand-hydraulic flaring tool and just would NOT flare, no matter how hard I tried.
Brian
