Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (41 chev), 120 guests, and 2 robots.
Topics128,275
Posts1,058,572
Members48,492
UURRR, I just have to vent. Driver's side door: begin with damaged outer cowl, rust, and never closed right. Full outer cowl replacement and a good piece of the inner kick panel. After all welded up, door fits fine, closes nice. Passenger side: begin with no damage, little rust and closed fine. Small lower outter cowl and kick panel rust repair. Today I have spent the last 2 hours trying to get the passenger door aligned and still not there!!!!!! 1/2" gap at top front with top hinge adjusted all the way in. Same door, same hinges (rebuilt), what the @$#*! Okay, deep breath, stiff drink and back to the garage.
1950 Chevrolet 3100 Deluxe Cab
Gallery Page
Webshots photos
This is just a hobby, this is just a hobby, this is just a hobby. Wait, hobbys are fun and relaxing right?!?!? :confused:
my advise to you, nifty 50 2, walk away from it. clear your mind, think about anything but the truck. Then when you get that feeling in your gut, calmly walk back to your baby and think, if i loosen these bolts and hold my tongue just right the vents will line up and the *&^%$#@#$%^ door will close with the touch of a finger! hang in there man, these trucks are worth it. If it was easy, everyone would be doing it!
Face it - you'd be pretty bored if none of this ever happened! LMAO
Nifty 50 2 ... if feel your pain! I just took a 2 month break because my truck was ready to send me to the looney bin.
Hang in there!
Nifty 50 2,
I used this info and it helped me no end, take a peek!
http://www.chuckthetruck.com/page20.html
Stuart
Just walk away and have a beer.
The crew that works on the \'42 --Sara, Hannah and Abby
Nifty,
Worry about the body lines and the door gaps.
I had to move the windshield post with a portapower after the door was properly gapped to get it fairly close. Sometimes it the bottom of the cab is rusted it will through the door openings out of wack.
my 2 cents,
Wilbur
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
Socket Breaker
Socket Breaker
old trucks are fun
old trucks are fun
-W
p.s. old trucks are fun
