| | | Forums66 Topics128,088 Posts1,056,390 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 40 Member | | Member Joined: Aug 2006 Posts: 40 | Got an "Aria" heater in my 52 Chevy 3/4. It's hooked to an old lamp switch and it works great. The problem is that even though there are defrost vents at the windshield, there are no ducts and there is no outlet on the heater to duct to the windshield. What's up with that? Will need the defroster worse that the heater this winter. Any ideas?
Dash Riprocker | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | heaters of this era, usually had a seperate (optional) motor assembly on top for defrost. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't know what heater you are referring to but for these trucks, the heater is usually either the "fresh air" heater or the "recirculating" heater. Either one has a duct outlet for the defrost and tubes connect them to the defrost ducts. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Heaters were an option back then & many were aftermarket. Some didn,t have defrost. You will need to get a heater with defrost or improvise a ductwork. We used to put a piece of wood on the edge of the hood & close it leaving a gap for engine heat to come out. Motoring was crude back then. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Aug 2006 Posts: 40 Member | | Member Joined: Aug 2006 Posts: 40 | Thanks guys....interesting stuff! Food for thought.
