4 members (Otto Skorzeny, mason86, dt235sd, 5 Window 9434), 83 guests, and 0 robots.
Topics128,050
Posts1,055,683
#215505 09/11/2006 2:12 PM
I am in the process of planning a disc brake upgrade to the front of my '63 which should vastly improve my stopping power, but I would also like to improve the rear drums. The brakes on my truck are not self adjusting and I would like to make them that way. I've thought about just ordering rear drum parts for a later model truck and putting them on my '63, but don't know if they will all hook up right. Do I also need to change the backing plate? Any ideas?
Daily Driver 63 C-10 LWB Fleetside
#215506 09/11/2006 2:25 PM
Tab Offline
My 62 has self adjusting brakes. I get out there and adjust them myself. grin
Sorry for the smartAzz reply. Can't answer your question but I will be interested to know the answer.
delete my account and pictures
#215507 09/11/2006 2:48 PM
Yea...that's the same adjusting systems mine has. Sure would be nice if they did it themselves.
#215508 09/11/2006 3:51 PM
The brakes are the same. All you need is the adjusting hardware. Any bendix with 11" should work. Some of the hardware upgrade you need should be obvious. Some, not so obvious. For example, The adjuster with star wheel has finer thread on the self-adjusters. At one time, you could find all of this at your local parts store. If there are some "old" parts stores in your area, you may be in luck. Otherwise, it is off to the bone yard.
#215509 09/11/2006 3:53 PM
BTW, GM cars went to self-adjusters in 63. Don't know when trucks went. Could be you originally had self-adjusters. Does anyone know when trucks went to self-adjusters?
#215510 09/11/2006 3:58 PM
I have a pretty good FLAPS that is manned by car guys instead of cashiers so maybe I'll stop in today and see what they say and if they can get me the parts from a newer set up.
#215511 09/11/2006 6:33 PM
My '66 has self-adjusting brakes on it. Taking the hardware off of a '66 would be a direct swap for a '63.
#215512 09/11/2006 6:52 PM
64 was the 1st year IIRC for the self adjusters,,pretty sure all rear drum hardware thru 72 will interchange,,even Autozone has the kits,,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
