1 members (UtahYork),
76
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 154 Member | | Member Joined: Mar 2004 Posts: 154 | well. after spending my friday night playing music with some friends in a basement, and a week of classes, i decided to get going on the truck again. today, was the firewall, as the title indicates. [img] http://i7.photobucket.com/albums/y297/samwise_/DSCI0002-1.jpg[/img] after taking the heater off, i discovered a small bit of rust. not alot. only a small bit, but enough to make me want to repair it. [img] http://i7.photobucket.com/albums/y297/samwise_/DSCI0003.jpg[/img] patch panels! thank you 1967 C10. [img] http://i7.photobucket.com/albums/y297/samwise_/DSCI0004-1.jpg[/img] close enough is good enough, eh? [img] http://i7.photobucket.com/albums/y297/samwise_/DSCI0006-1.jpg[/img] rust cut out. new metal in. [img] http://i7.photobucket.com/albums/y297/samwise_/DSCI0008.jpg[/img] yay for welding. [img] http://i7.photobucket.com/albums/y297/samwise_/DSCI0012.jpg[/img] ew. more rust. and some cut out. [img] http://i7.photobucket.com/albums/y297/samwise_/DSCI0013-2.jpg[/img] patch clamped in. i know they're plastic spring clamps. but they came off before they were melted...too bad. [img] http://i7.photobucket.com/albums/y297/samwise_/DSCI0021.jpg[/img] primered over. and. thats about it. took about..3 hours. yeah, i took a while. its okee. and don't laugh about fluxcore. it works. for the most part...lol. .later days. .sam. 1969 K20 , with a '67 front clip. fleetside. 292, 3x1 offy, headers. sm465 4spd. getting put back together, almost ready for paint. doing it all myself. 19 and lovin' it. "proper" is so over-rated. .later days. .sam.
| | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Nothing that touching it with a grinder won't make prettier! (if you care) Plus flux core does work outside in the wind too. | | | | | Joined: Mar 2004 Posts: 154 Member | | Member Joined: Mar 2004 Posts: 154 | yes, it does. we had about 5-10 mph winds yesterday, and it seemed to work out just find.
ugly? a bit. but, i knocked them down some, and since it's ging to get covered with the heater blower anyway...who cares! lol
| | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | Flux core is all I have and it has served me well. I have cut out quite a bit of rusted metal on my truck and welded in new patches with it. Takes a bit of grinding and a small amount of body filler to smooth it all out but it sure does work. | | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | sweet.. maybe i'll get motivated and give welding another try...
my father just knocks the high spots down with a grinder, then fills the rest in with RTV...
| | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | I hate to burst your bubble, but unless this is a fair weather truck, you may want to consider cutting your repair piece back out. There is a trough that directs the rain water across the top of that 4" hole and down the side, away from the kick-panel air vent. You can see part of that trough rusted out, in the top of the first picture. Without repairing the trough, the heater fan will pull the water into the heater suitcase and the water may also run into the kick-panel vent. There are actually so many pieces of tin, spot welded together in there, that it is hard to visualize. Coincidence that I just cut the inner part of that area out, on mine today. I don't have a rust problem. I'm putting in a non GM AC and I have to reshape the inside of the firewall, as well as eliminate the kick-panel air vent. It's always fun to weld upside down on my back. As I was cutting one piece away, I cut through into the inside bottom of that trough and left a 2" slit that I have to close up. That 4" hole will be closed off. Then a new upper inside corner piece and vent cover welded in.
'67 GMC 3/4 292 4spd
| | | | | Joined: Mar 2004 Posts: 154 Member | | Member Joined: Mar 2004 Posts: 154 | thanks for all the kind words and such.
and to richard, i checked out the trough..shelf...thing...
it's not in bad shape. and when i take more time to look at it, i'll fix it. namely, by welding it to the patch, so as to seal it off from the heater core area.
or, atleast thats the idea.
-shrug-
we'll see what happens.
thanks for pointing that out tho!
