3 members (HareCanvas, ArtA, papas52), 72 guests, and 3 robots.
Topics128,208
Posts1,057,452
Members48,471
I need help trying to figure out which motor mounts to use when upgrading from a 216 to a 235 since I read they have differnt types of motor mounts. I intend to install it in either my 49' 1 ton or a 51' 3/4 ton.
:confused:
Collecting is fun, as long as momma enjoys riding in them.
That subject is in the Tech Tips section. grin
You should be able to use your 216 mounts on the 235,i did when putting a 235 in my 37. You might have to drill two holes in the front plate for the mount depending on what year motor you are using
The engine is to be from a 1955 or 56. I wondered if there was a way tht the side motor mounts could be used instead of having to tear down the motor and use the front rubber one. grin
All 235's have the front motor mount plate, it's easy to drill the holes while the engine is assembled.
Or, if you get a '60-62 block, they changed back to the 216 style front mount.
Paint & Body Shop moderator
Far as I know, the only thing diff on the bellhousing was the ears that set on the frame are slanted on one, and flat on another. Just use your orig 216 b/house. You may have the two small mounts on front of your 56 engine, and not the one at bottom. You can still use one at bottom, but as said, may need to drill the holes for the bolts to mount orig type mount. The plate under timing cover is same, just no holes in later models. OR, can change whole plate between motors, much more bother, of course.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
