4 members (jay d, Donf, UtahYork, 1 invisible),
103
Mod | | | Forums66 Topics128,115 Posts1,056,633 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 16 New Guy | | New Guy Joined: Sep 2006 Posts: 16 | I recently purchased a 1949 chevy off ebay it came out of the manhattan store of old navy inside the glovebox it says the motor was a 501 and it had 2 rear axles, so I know the cab is off a large truck I don't think this will cuase any problem making it into a pickup will it? pretty hard to find a rust free 5 window up here so I was glad to get it, also I bought a frame several months ago and it was well redone, but is there somewhere that deal with brakes for that? it already has new springs and rod ends and king pins, but i need pads and brake cylendars. I'm sure I'll think of more ?'s.
Dan I'll work on gettin some pics up in a few minutes.
I swear to you Jerry the got a pig man down there, its half man half pig, I'll bet the military is breedin em for war.
| | | | | Joined: Sep 2006 Posts: 16 New Guy | | New Guy Joined: Sep 2006 Posts: 16 | heres a site where some of the pictures are, http://www.freewebs.com/my49chevy/ thanks dan
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | You sure it is a 49? That bed is not off a 49, and neither are the doors, due to the vent windows. | | | | | Joined: Nov 2005 Posts: 56 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 56 | The bed looks like it is off of a 1954, flat bed top rails. Pretty truck | | | | | Joined: Dec 2005 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 40 | Hes correct. The bed is from a 54-55 1st series and thats not a 49 cab. Its missing the side vent on the cab and the doors have vent windows! Either way Good Luck with your project. Hope you have as much of a blast with yours as i have had with mine! | | | | | Joined: Sep 2006 Posts: 16 New Guy | | New Guy Joined: Sep 2006 Posts: 16 | the vents are there on the cab,but it is covered in advertising tape soo thick you cant see them, I'll take another picture after I get the tape off, the bed you all would know better than me, what are the difference from the bed i have to a 49-50 bed?
Thanks Dan
| | | | | Joined: Dec 2005 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 40 | Not the vents on the passenger side. The cowl vent on the drivers side! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Dan, if I understand it, Old navy has a yard where they collect these trucks before they ruin them? That is very interesting. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | I agree that you have a 54/55-1st bed. The 47-53 beds "looked" the same but they did have different number of "bed planks". See if you can find the plate on the driver's side , hinge side of door jamb. It will have some numbers stamped in it. This will tell you what cab you have. The doors are NOT 1949 unless someone went to a WHOLE lot of work to convert them to vent windows. If your truck is rust free, you are way ahead of the game. Your truck is NICE, regardless of what year(s) it is.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
| | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | The easiest way I've found to tell if it's a '49 cab is to look at the gas tank and fire wall. If the tank is behind the seat and the panels in the fire wall are smooth, it's a '49. '50 to '53s had strength ridges stamped into the panels on the firewall.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Sep 2006 Posts: 16 New Guy | | New Guy Joined: Sep 2006 Posts: 16 | well the gas tank is and always was behind the seat, if you look carefully at the pass. side you can see the vents in the tape ahead of the door, the tape covers them pretty bad on the drivers side. the door may well have been changed, the cad is off of a truck with a 501 I cant say I expect it to be original, but if it miss matchs but I have doors that are so good that this guy was the first time it was in the rain in 15 years and the doors filled up with water, you know there is no rust and the fire wall was smoothe, but it had alot of hole, I'm guessing for the air brakes.
Thanks Dan
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | The louvered vents in the passenger side are for the heater inlet. I think all years have them. There should be a vertical door-type vent on the driver's side that opens with a lever. When they put in vent windows in 1951 the eliminated that vent. Doesn't matter what year you have as long as it looks good enough to you then it is good enough. Enjoy it. Bill | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Yep,54 bed,doors are 1951.What are the switches above the radio blank for ? I have looked at some of the old navy trucks and they are pieced together.I saw one, the whole floor pan was rotted out and the doors would bairly open.It had a beautiful chrome grille in it. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Aug 2006 Posts: 65 Member | | Member Joined: Aug 2006 Posts: 65 | Reminds me of that Johnny Cash song, one piece at a time, where he worked at a cadillac assy plant and brought parts home in his lunch box every day until he had enough parts to build a whole car! The steering wheel is also 54. That's a good looking truck though, especially since it came from Old Navy. What kind of restoration kit should he get from Chevrolet?  | | | | | Joined: Aug 2006 Posts: 65 Member | | Member Joined: Aug 2006 Posts: 65 | Dan, post some more pictures and take one of the hood emblem. Post the VIN # when you find it and we'll be able to tell exactly what year and model it is. | | | | | Joined: Sep 2006 Posts: 16 New Guy | | New Guy Joined: Sep 2006 Posts: 16 | thats why i bought it it had all the buitiful chrome, maybe this weekend I can pull the stickers off and you can see better, the cab is a gmc, i was looking in my chevy duty catalog and the nubers seemed different, di the chevy and gmcs use diferent number paterns?
Thanks Dan
Thanks Dan
| | | | | Joined: Sep 2006 Posts: 16 New Guy | | New Guy Joined: Sep 2006 Posts: 16 | I'm not sure if those knobs are even connected, I also notice it has a vacuum guage pickups didn't have that did they?
