| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 7 Junior Member | | Junior Member Joined: Oct 2005 Posts: 7 | Where do I start? I have a '49 Chevy 3800 dually and want to get rid of the split rims. I want to use new chrome wheels that will support better truck tires. I want to do this now since I have to replace all 6 tires. HELP! | | | | | Joined: Oct 2005 Posts: 7 Junior Member | | Junior Member Joined: Oct 2005 Posts: 7 | The wheels do not have to be chcrome - I just want something other than the split rims. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | post this in the big bolt section. you may get a little more help. i'm not sure of your lug pattern ... is it 8 on 6.5 inch bolt circle? if it is you should be able to use most any rim, chevy, dodge, or ford. you should watch the backspacing to avoid any tire rub issues. | | |
