4 members (walter74, 32Fordpuchoptop, Hotrod Lincoln, 1 invisible), 111 guests, and 1 robot.
Topics128,035
Posts1,055,443
Members48,422
#215239 09/07/2006 1:52 PM
Junior Member
Junior Member
Where do I start? I have a '49 Chevy 3800 dually and want to get rid of the split rims. I want to use new chrome wheels that will support better truck tires. I want to do this now since I have to replace all 6 tires. HELP!
#215240 09/07/2006 5:38 PM
Junior Member
Junior Member
The wheels do not have to be chcrome - I just want something other than the split rims.
#215241 09/07/2006 11:38 PM
post this in the big bolt section. you may get a little more help. i'm not sure of your lug pattern ... is it 8 on 6.5 inch bolt circle? if it is you should be able to use most any rim, chevy, dodge, or ford. you should watch the backspacing to avoid any tire rub issues.
