1 members (walterhvogel), 87 guests, and 3 robots.
Topics128,035
Posts1,055,559
#21521 11/25/2002 4:04 AM
i got a 51 with a 235 in it. can't get the timing cover off..
removed all screws..
having trouble with oil seal
no clue what to do with out breaking stuff
#21522 11/25/2002 4:25 AM
There are two bolts that hold it on from the inside the crankcase. You have to take the oil pan off to get at them.
1951 1 Ton Completed
#21523 12/02/2002 4:20 PM
can't get the oil pan off...
removed "all" bolts still no luck
the thing has been sprayed with wd
probably just been sitting too long
when i got it id had been touched since 74
#21524 12/02/2002 6:10 PM
Your oil pan is probably glued on with the gasket. Drive a putty knife between the gasket and the block, the start working around until it comes loose. Be careful not to bend the oil pan flange. It can be straightened, but it is better if you don't have to. Also, when you do get it apart, it is common practice to tap the holes in the front main bearing hub and put the bolts in the timing cover in from the front so you don't have to drop the pan the next time.
Fred
52 3600
69 C-10
#21525 12/02/2002 7:12 PM
good idea,
i forgot that they used to be glued
i was thinking that there may be some
obscure method for removal
thanks alot
i'll everyone post on progress
should have pick soon
#21526 12/04/2002 4:24 PM
used a putty knife.
came off like a charm
i guess i didn't need brute force after all
just 99c putty knife
