| | | Forums66 Topics128,034 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21521 11/25/2002 4:04 AM | Joined: Nov 2002 Posts: 33 Member | | Member Joined: Nov 2002 Posts: 33 | i got a 51 with a 235 in it. can't get the timing cover off.. removed all screws.. having trouble with oil seal ???? no clue what to do with out breaking stuff | | |
#21522 11/25/2002 4:25 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | There are two bolts that hold it on from the inside the crankcase. You have to take the oil pan off to get at them. | | |
#21523 12/02/2002 4:20 PM | Joined: Nov 2002 Posts: 33 Member | | Member Joined: Nov 2002 Posts: 33 | can't get the oil pan off... removed "all" bolts still no luck the thing has been sprayed with wd probably just been sitting too long when i got it id had been touched since 74 | | |
#21524 12/02/2002 6:10 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Your oil pan is probably glued on with the gasket. Drive a putty knife between the gasket and the block, the start working around until it comes loose. Be careful not to bend the oil pan flange. It can be straightened, but it is better if you don't have to. Also, when you do get it apart, it is common practice to tap the holes in the front main bearing hub and put the bolts in the timing cover in from the front so you don't have to drop the pan the next time.
Fred 52 3600 69 C-10
#21525 12/02/2002 7:12 PM | Joined: Nov 2002 Posts: 33 Member | | Member Joined: Nov 2002 Posts: 33 | good idea, i forgot that they used to be glued i was thinking that there may be some obscure method for removal thanks alot i'll everyone post on progress should have pick soon | | |
#21526 12/04/2002 4:24 PM | Joined: Nov 2002 Posts: 33 Member | | Member Joined: Nov 2002 Posts: 33 | used a putty knife. came off like a charm i guess i didn't need brute force after all just 99c putty knife | | |
