1 members (1 invisible),
78
Mod | | | Forums66 Topics128,034 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | well i did a search for this and i am sure it has been talked about, my bolt is a 6 volt, my charger is a 12 volt5 2 amp unit, it goes buzzzzz real load when i put it on at the lowest setting, yes i did disconect the cables for fearing i would blow the head lamps out!!! | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | You may have fried your gas gauge. Everything else is pretty tolerant of 12v... The Lightbulbs would only be an issue if you had them on when the charger was running.
Get one that does six volt. A cheapish good one is available at your FLAPS, or at Meijer/Walmart/et cetera. | | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | Now, this would be a real nice topic for the electrical bay. | | |
