12 members (Joe H, Gray_Ghost, Woodcmiami, fonz8261, 2-Ton, cmayna, 55shaker, kades51, Forty9, NorthCoast3800, Robert Crandall, 1 invisible), 103 guests, and 3 robots.
Topics128,169
Posts1,057,037
Members48,458
#21489 01/24/2004 3:16 PM
Junior Member
Junior Member
Help!
I can't find replacement brake shoes for my 51 3/4 ton. This truck has Huck type brakes and I can't find them. Any know about this or a reasonable relining service in central Fla.
1951 Chevy 3600, 1996 Yukon, 2000 Road King
It is easy to take liberty for granted, when you have never had it taken from you.
http://www.stovebolt.com/gallery.htm
#21490 01/24/2004 3:22 PM
Either Jim Carters or American Classic Truck parts can supply the shoes for you and very reasonable in price.
1936 GMC T-14 1/2-Ton Pickup
#21491 01/24/2004 3:36 PM
Junior Member
Junior Member
Thanks for the reply, I can get the shoes for the rear of my truck from Jim Carters, I just thought $84.75 with a $75 core charge was a bit steep.
#21492 01/24/2004 3:59 PM
Hello,I Just Saw A Pair Of Rear Brake Shoes On E-Bay.There Under 1950 GMC I Hope This Helps You!! GMCJOHN
JB
#21493 01/25/2004 12:34 AM
I didn't realize that there was that much difference in the price of shoes for "Hucks". Mine ran about $25 per axle with a $15 core charge. Got all of mine from Jim Carters.
#21494 01/25/2004 2:57 AM
Junior Member
Junior Member
It seems the [[[1951 3/4]]] ton has an unusually expensive brake system to rebuild.
#21495 01/25/2004 3:19 AM
Check around in you area if there is a brake relining place, I had 12*2 1/2 done for one of my cars for $20cdn and axle. and they where re bonded to the old shoes.
#21496 01/25/2004 3:25 AM
Junior Member
Junior Member
Albert,
Beleave ot or not, I have been trying to find a reining vender. no luck yet
#21497 01/25/2004 3:28 AM
Junior Member
Junior Member
sorry for the typos, tried to type with the light off, bad call on my part.
#21498 02/09/2004 6:37 AM
Aloha, my local brake "guru" used modern, **** (gasp) 4WD brakeshoes with no other modifications on my '59 Lbed fleetside Apache that carries a '58 alaskan camper weighing approx. 1000 lbs and it stops on a dime, no heating/fading or anything, very sweet, it also has hydra-vac powerbrakes but the shoes made a killer differance, i'll ask which ones they were and post it IF he'll reveal his trade secret. They really work good.
#21499 02/09/2004 3:42 PM
If the shoe cores aren't damaged get them relined. Another option is to replace the entire brake system with Bendix from a 52 or later. On the fronts you disconnect the brake line and unbolt the backing plate, then replace from a donor. IIRC, the bendix front shoes are available from a local parts store, along with new cylinders. Rears need to be relined.
Fred
52 3600
69 C-10
#21500 02/09/2004 7:07 PM
Try Kanter Auto Parts . They have a 4 wheel kit with all shoes for $140 plus $75 core. I have used them and was very satisfied.
Professional Novice
#21501 02/10/2004 2:07 AM
When I put new front shoes on my '48 3/4T, my parts store found an Oregon company which was getting rid of all their old shoes. They were $17. I never realized that these Huck shoes were so special. I should have bought more.
#21502 02/12/2004 6:32 AM
For the brake relining, consider going to a large diesel truck stop or a local COOP shop. They might know of a place that does that type of work. I had my clutch for my 37 chevy redone and had other light duty car brakes redone at the same shop when there main work was big trucks.
Good luck.
Brent
