| | | Forums66 Topics128,115 Posts1,056,288 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | I've been pretty good about keeping up with the rubber parts on my '62 but I overlooked the oil filter hoses. I filled it up with gas to haul hay yesterday and when it got back to the yard, one let go. It unloaded the oil pan right now. Ended up using the Dodge to haul hay. Anyway, my point is if your lines have a few years on them or are original, it might pay to change them. When they go, your done until the new ones come in.
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | When I got my 38 running that was one of the first things to start leaking. fortunately napa had them in stock. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you can't find them in srock at the flaps, any place that makes hydraulic hoses can make them.
Bill Burmeister | | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | That's the fun part of breaking down on a long weekend. No one but Checker is open, and I don't have the patience to explain it to the youngsters there. We have a setup at work to build hoses but not that small. They are ordered, so it should be back to work in a couple days.
Joe McNeel
