4 members (MickeyP, Lostbuthaulinass, Wally / Montana, 1 invisible), 122 guests, and 3 robots.
Topics128,050
Posts1,055,753
#2146 04/04/2003 5:54 AM
I have 4200 miles on my 53 3800 1ton rebuild. Lately, I have been getting a weird sound when I accelerate, especially up hill, in 4th or 5th gear. The sound is like a LOUD valve rattle but it is definately not the valves.
I have an 89 Camero T5, 11in clutch mounted to a 261.
This noise only occurs under load and doesn't seem to be the throwout bearing but is coming from the rear of the engine /clutch area.
Any suggestions what to look for as I tear things apart in my futle attempt to convince my wife that I CAN fix it?
#2147 04/04/2003 9:35 AM
Use higher octane fuel and or adjust timing smile
#2148 04/04/2003 12:39 PM
Detonation can be caused by a lean fuel condition, too low octane, bad timing, or a combination of these. Luke is dead on; pour some octane booster into the tank and check the timing. If everything checks out and you still have the problem, enrich the mixture. You'll lose a bit on economy, but you get to keep your engine.
I don't suppose downshifting is an option? Didn't think so. wink
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#2149 04/04/2003 1:54 PM
Thanks, I'll try that this morning. It would be great if it tunns out to be something that simple!
#2150 04/04/2003 8:13 PM
Is it accompanied by a loss of power, popping, and sputtering? If it is, your power valve in the carb isn't opening.
If it's not, most likely the points have worn enough that your timing got too far advanced. Tune it up first and then worry about gas, it's unlikely that regular unleaded is too low since 261's only have 7.8:1 compression on a good day.
Paint & Body Shop moderator
#2151 04/06/2003 2:34 AM
Thank you, folks! You all saved me from a lot of needless work and expense. The timing was way off, I cleaned and regapped the plugs, adjusted the carb and added a bottle of octane booster. No more rattle, smooth running and more power.
I was looking in the wrong direction. Thanks,Don.
#2152 04/07/2003 4:45 AM
We're glad you got it fixed up before damage set in.
#2153 04/07/2003 7:08 AM
Great to hear things worked out smile
Happy bolters are a positive influence on us all cool
