| | | Forums66 Topics128,087 Posts1,056,115 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 172 | heres the pics: pic1 pic2 im tryin to figure out what that little tab thing sticking off the drivers side frame rail under the cab is. i took a pic of it from the front and from the back. im shortening the frame so i need to know if it can come off of there and not affect anything. thanks patrick | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | exhaust hanger mounting point, prolly about where the muffler goes
Bill | | | | | Joined: Apr 2006 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 172 | so it can be removed and no problems i guess?? or do i just put in a new one later? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you could do without, but the factory hangers are handier than makeshift - I'd grind off the rivet and weld it back on in about the same place
Bill | | | | | Joined: Apr 2006 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 172 | | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Might be the mount to hang a return spring....have a double one on my 54 for the clutch and brake return springs. | | | | | Joined: Jan 2002 Posts: 36 Member | | Member Joined: Jan 2002 Posts: 36 | It is for the return spring for the parking brake. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | An alternative. If it is an exhaust hanger, remove it. If it is a bracket for a spring, measure the distance between spring ends, then remove the bracket. After you shorten your frame, if you find you can't live without the bracket, drill some holes and remount it to your frame. If you don't need it, you now have a cleaner looking frame! | | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | I would guess it has something to do with the park brake cable.
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: Mar 2003 Posts: 181 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 181 | It's an exhaust bracket. My 65 has it too and that is what the 44,000 mi original truck had attached to it. | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | It looks like where the clutch spring ataches.Is it at the front or back? | | |
