1 members (J Lucas), 85 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#214555 08/27/2006 11:37 PM
Apprentice
Apprentice
I have a Canadian 1966 chevy truck. Can't seem to find a decode for the vin number.... Can anybody HELP ?????
1 st. line ( 6C1534623100A )
2 nd. Line ( FTO33273-paint5002 )
Thanks guys......
#214556 08/28/2006 1:44 AM
Did you get these #s off the id plateor the GVW plate? The vin plate should be on the left hand roof rail. From what I can decipher from the #s you gave is that it's a '66 2wd 1/2 ton 127" wheel base Fleetside, possibly black originally.
Bill Burmeister
#214557 08/28/2006 1:52 AM
Apprentice
Apprentice
I got it from the plate on the roof rail. Have pics from another owner of the truck that shows it seafoam green.... any more information would be great.......
#214558 08/28/2006 1:54 AM
Apprentice
Apprentice
Bill just looked at your pics... tell me about your truck please the intake is it water heated ???
#214559 08/29/2006 1:51 AM
No, the intake isn't heated, I have considered adding heat though. The truck itself is a '55 model 3200, 235 with 3 speed originally, now has an overdrive 3 speed. The engine is the original 235, bored .060", head milled about .010". It has a Howard M4F 3/4 race cam, Offy intake/Fenton exhaust combo, and Mallory ignition with a 3rli spark box/rev limiter. The carbs are Holley model 1904, originally from '56-66 International 1 1/2 ton trucks. I had to custom fab the linkage to make them work. Most of the rest is basicly stock, other than colors. I got lucky with some of the options, it had the rear bumper, turn signals, and heavy duty springs on it when I got it, the backup lamps were a lucky swap meet find, as was the trans.
There is a possibilty that Canadian trucks have some different codes from the US versions, my books only list the US numbers. Perhaps some of the 'Bolter from up North might be able to get some more accurate informaton for you.
Bill Burmeister
#214560 08/29/2006 2:10 AM
I'd guess from earlier year conventions, 6C1534623100A=
1966 Chevrolet model 1534 engine 6cyl build sequence# 23100, not sure about the A but it might be trans type
Scotts Super Trucks in Alberta would likely know the codes
#214561 08/29/2006 2:52 AM
An "A" code on a US truck would usually mean that it came from the Atlanta plant, not sure on a Canadian truck, could have been brought over, maybe?
Bill Burmeister
#214562 09/01/2006 12:27 AM
Apparently the Canadian VIN is different than the United States trucks. Perhaps you can find the information in the owner's manual, or at a Chevrolet dealer in your area.
