0 members (),
119
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 321 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 321 | had a charging issue so i decided to go through the system to diagnose the problem. in the process of re-installing the generator, it slipped and fell to the ground. when i picked it up, the casting on the back side had broken off at the mounting point. needless to say there were a few choice words that echoed through the neighborhood.
is it worth trying to "weld" the piece back on or find a donor part or just replace the unit entirely?
any and all opinions are welcome... | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I would just replace it unless you plan on dropping it again.............just kidding..... Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | I have done almost the same thing I Tigthened mine too much and broke the housing. i got a donor part but felt like an idiot | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | P.J.
I did the exact same thing. Yep, I felt like an idiot. Especially when I'd just gotten it out of the generator rebuilding shop that morning.
Sure looked foolish taking it back first thing the next morning. | | | | | Joined: Jul 2005 Posts: 71 Member | | Member Joined: Jul 2005 Posts: 71 | It can be successfully welded with a nickel-based rod if you don't have a replacement part. | | |
