2 members (Hotrod Lincoln, Shade Baby), 66 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
#214524 08/27/2006 2:15 AM
had a charging issue so i decided to go through the system to diagnose the problem. in the process of re-installing the generator, it slipped and fell to the ground. when i picked it up, the casting on the back side had broken off at the mounting point. needless to say there were a few choice words that echoed through the neighborhood.
is it worth trying to "weld" the piece back on or find a donor part or just replace the unit entirely?
any and all opinions are welcome...
I would just replace it unless you plan on dropping it again.............just kidding.....
Redryder pix
My Hotrod
I have done almost the same thing I Tigthened mine too much and broke the housing. i got a donor part but felt like an idiot
Jed Offline
P.J.
I did the exact same thing. Yep, I felt like an idiot. Especially when I'd just gotten it out of the generator rebuilding shop that morning.
Sure looked foolish taking it back first thing the next morning.
#214528 08/27/2006 10:57 AM
It can be successfully welded with a nickel-based rod if you don't have a replacement part.
