1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#214038 08/19/2006 4:58 AM
V
V Offline
Does anyone know what is interchangable or upgradeable from a 79 onto a 66 C10. i.e. Seats, brakes, rear.
Thanks.
1966 C10 250/3 Stepside
1966 C10 327/3 Fleetside
1972 Buick Centurion 455/TH400
1964 Plymouth Valiant 360/A833 4spd
1964 Plymouth Sport Fury 440/727
I've got a new car....It was made in '72
#214039 08/19/2006 4:24 PM
whole front suspension,steering box with a kit,rearend with a kit,seat with a drill,steering column with a drill?,power booster/mastercylinder witha drill?
64 c10
89 rs
62 econoline
50 ford coupe
#214040 08/20/2006 4:41 AM
V
V Offline
Thanks. That's what I needed to know.
#214041 08/20/2006 11:11 PM
I am swapping in the front spindles with disc brakes into my 65 from a 84 C10. I am also adding the power steering box, power brake master cylinder and the rear axle (10 bolt with a posi!) The rear axle required me to cut the spring perches off and weld on custom made ones for the trailing arms to meet up with. I also had to fabricate the track bar mount. If you are swapping in a 12 bolt to a 12 bolt, then you can just gut the old one and pop in the newer parts to the old housing. Saves on the fabrication part.
1965 Chevy C-10 Longbed Stepside
#214042 08/21/2006 2:41 AM
V
V Offline
Are the axels the same length? Or do you have to have them cut down?
