3 members (Lightholder's Dad, 2-Ton, TooMany2count), 83 guests, and 3 robots.
Topics128,024
Posts1,055,393
Members48,422
#213708 08/14/2006 5:41 PM
Anonymous
Unregistered
Anonymous
Unregistered
Decided the truck needed to start looking like a truck again so we started re-hanging the front sheet metal. Got the inner fenders in place on Saturday and hung the outer fenders on Sunday. Was hoping to install some auxillary coolers behind the grill but there appears to be only room for the future AC condenser so the auxillary tranny and engine oil coolers, if used at all, will need to be mounted off the frame once the exhaust piping is done.
The radiator core support needs to shimmed up a bit to improve the sheet metal alignment.
This week should find me doing the block sanding on the doors and installing the tailgate with the new Pro's Pick latch kit and straps.
Here are the pictures from this weekend:
http://www.picturetrail.com/gallery/view?p=999&gid=8309838&uid=2902753
#213709 08/14/2006 7:51 PM
Looks great! I bet the itch to drive it is starting to set in now.
-Rich
#213710 08/15/2006 3:28 AM
Houston....what did you do to your grille....I'm curious.
#213711 08/15/2006 12:48 PM
Anonymous
Unregistered
Anonymous
Unregistered
It is painted the color the rest of the truck will be hopefully soon.
#213712 08/15/2006 2:07 PM
Houston54,Lookin good,its got the stance,,you know like man I will blow your doors off at the next stop light.
