4 members (Otto Skorzeny, Phak1, TrknGMC, Bill Marlow), 67 guests, and 1 robot.
Topics128,049
Posts1,055,548
Members48,425
#213692 08/14/2006 5:20 AM
I have a 65 4x4 with a 283 - no power steering and no A/C - that I am going to be pulling out in the next couple of days and puting in a 350 from a 79 and it DOES have power steering and A/C...
what do I have to take off and add to the 65 when setting up for the 350 with power steering pump in order for the components... ie steering shaft, tie rods etc to work right? I assume there are things like that to consider? any help?
Boogity, Boogity, Boogity Let's go racin boys.
Drive fast, turn left. GO #20.
Real trucks where bowties.
#213693 08/15/2006 1:38 AM
The tie rods and drag link shouldn't be a problem. What you need to look at is the steering box itself. You will want to comare it to a later integrated power steering box to see what will fit your frame. You will want to look into reinforcing the frame in the area that the box mounts to as well, as this is the traditional weak spot on Chevy 4x4 frames. I would look at the '73-'87 4x4s for a steering box, can't say that it would work, but it seems to be the logical place to start.
Bill Burmeister
#213694 08/15/2006 6:17 AM
That's something I had thought about much... guess I better consider that though... thanks Bill. Are there any other issues that I'll run into or is that pretty much it?
#213695 08/16/2006 2:56 AM
bowtie65:
I have done the power steering conversion on two different '66 K10's. You will need the power steering conversion kit that reinforces the frame rail at the power steering gear box mounting location. Additionally, the frame rail must be drilled in two locations in addition to the holes already in the frame rail to accept the manual gear box. I sell a stainless steel conversion kit that I developed after purchasing and installing a few of the kits on the market.
In any event, this is a popular conversion on the '60-'66 Chevy trucks and I highly recommend it. I have purchased a few complete kits on eBay, including the power steering box, power steering pump, hoses, brackets, pulleys and instructions with very good success. Good luck with your conversion.
#213696 08/17/2006 4:04 PM
thanks 4-5-6, how much are you asking for your stainless steel conversion kit?
