| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 81 | I have a 65 4x4 with a 283 - no power steering and no A/C - that I am going to be pulling out in the next couple of days and puting in a 350 from a 79 and it DOES have power steering and A/C...
what do I have to take off and add to the 65 when setting up for the 350 with power steering pump in order for the components... ie steering shaft, tie rods etc to work right? I assume there are things like that to consider? any help?
Boogity, Boogity, Boogity Let's go racin boys. Drive fast, turn left. GO #20.
Real trucks where bowties.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The tie rods and drag link shouldn't be a problem. What you need to look at is the steering box itself. You will want to comare it to a later integrated power steering box to see what will fit your frame. You will want to look into reinforcing the frame in the area that the box mounts to as well, as this is the traditional weak spot on Chevy 4x4 frames. I would look at the '73-'87 4x4s for a steering box, can't say that it would work, but it seems to be the logical place to start.
Bill Burmeister | | | | | Joined: Aug 2005 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 81 | That's something I had thought about much... guess I better consider that though... thanks Bill. Are there any other issues that I'll run into or is that pretty much it?
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | bowtie65:
I have done the power steering conversion on two different '66 K10's. You will need the power steering conversion kit that reinforces the frame rail at the power steering gear box mounting location. Additionally, the frame rail must be drilled in two locations in addition to the holes already in the frame rail to accept the manual gear box. I sell a stainless steel conversion kit that I developed after purchasing and installing a few of the kits on the market.
In any event, this is a popular conversion on the '60-'66 Chevy trucks and I highly recommend it. I have purchased a few complete kits on eBay, including the power steering box, power steering pump, hoses, brackets, pulleys and instructions with very good success. Good luck with your conversion. | | | | | Joined: Aug 2005 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 81 | thanks 4-5-6, how much are you asking for your stainless steel conversion kit?
