| | | Forums66 Topics128,088 Posts1,055,993 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 17 Junior Member | | Junior Member Joined: Jul 2006 Posts: 17 | I got a 65 chev last month drove it home 45 miles but there is a bad dent in the driver side fender can t be fixed found a 1 ton with good fender does any body know if there the same it looks like it might it just have bigger suspenind
his there any home reamaties to clean rust out gas tank or is it worth the money to get it steam clean as soon as i put new gas in my line and filter kept getting plug im running new line to a jerry can for time being
has any ever put air suspend on there truck i want to all wood with it but thr old coil sag real bad or maybe just the block of wood treatmeant thank you so much for this site you already anwerd my question on carb in another forum it nice to talk to guy that arnt all hung up on the 1970 thre 78 truck sorry about my spelling i can t spell sh$$t later :confused:
You have to stand for somthing or you will fall for anything
| | | | | Joined: Jun 2005 Posts: 3 Junior Member | | Junior Member Joined: Jun 2005 Posts: 3 | Madtrapper,
Welcome and I love your Name.
My .02 on your gas tank. Having tried many short- cuts to cleaning tanks in cars,trucks,Atv's, and even ski-doo's, YOUR best bet is to remove the tank and flush it out real good (I usually throw in some marbles and slosh them around). I just use water from a hose and then dry the tank real good....new line and filter and you should be good to go..... you'll Thank yourself many times over for taking the extra time and efforts...it will pay off in spades....and if you have additional engine problems, you have already eliminated the gas flow question.
In fact, driving home 45 miles, you did "some good".
Try fixing one or two little things every day or so, and in six months you'll be one happy camper.
I've done my 52 over the last year just by reading here on the Bolt everynite. Good Luck!!!!
52 Chevy Blue 3 Ton
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | There are few gas tanks that can't be cleaned. Many jobbers sell kits that include a cleaner (phosphoric acid), neutralizer (ketone) and a coating. I did mine using muratic acid (the same stuff used in swimming pools), baking soda water to neutralize the acid and Redkote sealer. There have been some extensive threads about this very subject. I'd advise using the search function above. Welcome to the bolt.
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | We can get by your spelling (with me it's the typing) Welcome aboard. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That one ton fender should fit just fine, the main differences are in the suspension and chassis equipment.As far as 'bagging it goes, I ahve seen it done on '64-'72s, the suspension os similar on those models. I'd suggest that you check out Air Ride Technologies. They seem to be the major manufacturer of air suspension in the aftermarket.
Bill Burmeister | | | | | Joined: May 2006 Posts: 30 Junior Member | | Junior Member Joined: May 2006 Posts: 30 | I just recently took my tank out of my 59 and took it to the car wash and power washed it with hot water and soap. then rinsed it, sprayed the inside with w-d40 and put it back in filled it up and put heat in it to get any moisture out. no problems yet and its been a couple weeks. You won't believe how much stuff will come out of your gas tank. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | welcome to the SBP.  | | | | | Joined: Jul 2006 Posts: 17 Junior Member | | Junior Member Joined: Jul 2006 Posts: 17 | thank you all for the help i will have many quoestion to come
any advice on hoe to conveince my wife that 4 knew ties for the truck is more inportant then the kids school supply LOL why do let her to the budget
| | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | Welcome aboard madtrapper! If you use the truck to drive the kids to school then new tires are 'school supplies' Right?
1948 AD Pickup
| | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | Madtyper, welcome to the 'bolt!! YOu have GOT to be from Manitober, RIGHT!! Those Tires are no less impotent than the kids school supplys, that is foe shure.
| | | | | Joined: May 2006 Posts: 30 Junior Member | | Junior Member Joined: May 2006 Posts: 30 | Well I spoke to soon thought the tank was clean but it has been about two weeks and the rust is back so I am giving up and buying a new tank tommorrow. | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I just bought a new tank for my '54 GMC. I figured it was a whole lot less trouble than fooling with trying to clean the old one and only cost me $160.00. Now I know I won't have any problems with "junk" from the tank clogging fuel lines. | | |
