11 members (52Carl, carbking, Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, fonz8261, greenie-reddy, 2 invisible),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,124 Posts1,056,347 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21347 07/22/2002 6:07 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | When I checked the steering box in my 50 3600, it has noodles of old chassis lube in it I was going to try to drain & pluck what I could, and refill with gear oil. Any thoughts on how to flush it all out? | | |
#21348 07/22/2002 6:25 PM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | If you have the steering box off the truck you might try a product like that Gunk that is mixed with kerosene, or even straight kerosene in the box to soften and remove most of the grease. I don't know that a little grease will hurt the box anyway. Good luck.  | | |
#21349 07/23/2002 1:52 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | People sometimes fill the box with grease when it is leaking. I am not saying that it is correct but it is done. | | |
#21350 07/23/2002 4:31 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Chassis grease was a recommended substitute for the gear box lube. I recommend one of the moly types, the lithiums get stiff when cold. If you are going to use gear lube you will need to put a pan under the truck to catch the drips, it's too thin.
Fred 52 3600 69 C-10
#21351 07/23/2002 4:40 AM | Joined: Feb 2001 Posts: 39 Member | | Member Joined: Feb 2001 Posts: 39 | i was wondering about this myself. my steering box leaks, so what you guys are saying is i could put grease in it? i was thinking it would work just fine, i guess i just needed someone else to reassure me!
1948 GMC 250 Series Flatbed
#21352 07/23/2002 5:27 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I've been usin a moly grease in all my old steering boxes for 15 years [including my old forklift!] and it works fine, and keeps everything under there cleaner.
Bill | | |
#21353 07/23/2002 8:33 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | It is important to use a lube in the steering box that stays semi fluid and does not 'channel' . If you are set on using grease instead of the correct lubricant , then something like , L-MOS 2 , or similar soft moly seems to work . Many regular wheelbearing greases are too stiff and can cause galling of the worm or sector , with the resultant risk of binding. I was taught never to use grease in a steering box for this reason , best , I think , to fix the leak and run the factory recomended lube (gear lube). | | |
#21354 07/23/2002 11:56 AM | Joined: Jan 2000 Posts: 125 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 125 | GM makes a lubricant to use in leaking steering boxes. I don't have it's part # but found it in a dealers book of lubricants under manual steering lubricant. It's thicker than 90 weight and cured my leaking problems. Even my newly rebuilt box leaked until I used this-used two tubes.
Grant 1950 Chevy 3100 1952 GMC 150 (In Pieces) 1968 Chevy K20 1966 Shovelhead 1978 BMW 100S
#21355 07/23/2002 12:27 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | The GM part number for that steering lube is 001052182. I paid about 6 bucks for a tube. My steering box took about a tube and a half..Great stuff..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#21356 07/23/2002 2:26 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | Thanks everyone, GM has dis-continued that lubricant. My local dealer was out, referred me to a Hesser Oldsmobile in Madison WI 608.754.7754. They had 8 yubes left. I bought 2. | | |
#21357 07/23/2002 4:12 PM | Joined: Feb 2000 Posts: 90 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 90 | I can not remember where I read this, but I used about half hypo gear oil and half moly grease (mixed)and all seems smooth and not much seeping. Has anyone else tried this?
1953 1/2 ton Chevrolet | | |
#21358 07/24/2002 11:48 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | I could not find the GM lube, at least not for a decent price. I see American Classic has it, but I also noticed they recently raised their price of it by 250%. I know they support this site, but I think a price hike of that magnitude is just plain robbery. So I got some steering box lube made in Australia, company name of Penrite. Really thick stuff, also not cheap. It leaked past my new sector shaft seal, but I got a genuine GM seal and put it in, replacing the cheapo one that came with the rebuild set from Chevy Duty. Now no leak at all. | | |
