9 members (Peggy M, JoeDude, Hotrod Lincoln, Perro, 48jim1ton, Shaffer's1950, Stovebolt48, Donf, 1 invisible),
93
Mod | | | Forums66 Topics128,032 Posts1,055,516 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 15 Junior Member | | Junior Member Joined: Mar 2006 Posts: 15 | My mechanic lost the plastic gear that goes in my 3 speed manual transmission for the speedometer. Where can I get a replacement. 1967 c10 250 3speed manual. Help I am going to be breaking the motor in on Friday and look forward to getting her on the road. A speedo would be a plus. Thank you | | | | | Joined: Apr 2005 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 20 | sounds like a trip to lmc.com to me. i dont have the catalog handy but i would guess that would be the easiest way to get one. all i have here is stuff for the th350's | | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | Go to your local gm dealer. Tell them your rearend ratio, color of gear in the trans, and if you know, the number of teeth on your speedo gear (which you have lost). they can fix you up for about 6 bucks. | | |
