| | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | So I have a 56 235 in my 46 and I have yet to get a reading on the temp guage witch I think is about the same. I think I have it all wired right and it runs but I haven't seen even a blip on the guage. Any ideas? Brian
1946 1/2 ton I'm not addicted I just don't know when to stop
| | | | | Joined: May 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 119 | Electric or mechanical gauge? | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Try hooking 12v to it direct while someone watches the needle. Then a resistor in there to drop the voltage. Be nice to know if the gauge works at all. Assuming wired all right means its electric. Mine sometimes reads and sometimes doesn't and I think its the wire connecting to the sender. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | A safer way might be to use a test light to make sure the "Bat" or "Ign" side is getting voltage, then ground the "sender" side. The needle should go all the way to hot.
Evan
