2 members (J Lucas, lumbersawyer), 129 guests, and 1 robot.
Topics128,047
Posts1,055,538
Members48,424
#2127 02/01/2003 12:28 AM
If I wanted to ship the rear end of my truck do I understand it right that the pumpkin seperates from the rear axle? So, you just ship the pumpkin? Or is it all one assembly? AD 1/2 ton.
54 3100 with 235
62 flatbed dump C60 with 261
#2128 02/01/2003 12:33 AM
Yes, you can remove the axleshafts, disconnect the torque tube, and pull the "third member" and ship it.
Paint & Body Shop moderator
#2129 02/01/2003 12:51 AM
Ok this is the thing. Patricks rear end kit will work on a 54 truck he says but you have to:
Quote
use the 40-53 differential spool casting
#3652336. Otherwise, the installation is exactly the same. That change was done only in 54, so in order to make it work, you need the early differential.
So, on my luckiest day I find an earlier differential with the Patricks pinion change already installed but need to have it shipped over here. Am I right to think that all I need to do is swap in that third member for my own to make it work? What about hooking up to my existing torque tube and axles?
54 3100 with 235
#2130 02/01/2003 3:31 AM
Tony M,
Am I correct to assume that since you have a 54 that you cannot simply swap the entire rear drive line "T" (axles, torque tube, etc) ?. If you can, then why not go that direction ? Is it because of the additional freight to ship an intact complete rear driveline ?
Craig
Craig
#2131 02/01/2003 4:55 AM
Yes I figured shipping something that big would cost more and those parts are in really good shape on my own truck. But thinking about it, maybe somewhat broken down it could still all fit on a pallet. I am not sure how long the longest part would be. The extra weight would be negligable on the shipping bill. Size would hurt.
Still hoping to hear from the experts on this forum. But will contact Patrick's again on Monday to get the skinny.
54 3100 with 235
#2132 02/01/2003 5:51 PM
Tony M,
Obviously the torque tube would be the governor as far as dimensions go, but who knows how much an entire driveline weighs ????
Craig
#2133 02/02/2003 2:40 AM
Apparently nobody on this website. I will get my info from Patricks on Monday.
54 3100 with 235
#2134 02/02/2003 3:27 AM
Anonymous
Unregistered
Anonymous
Unregistered
From what I can gather from Patrick his ring & pinion kit will NOT work on the '54 3:90 rear end & he says you must locate a '47-'53 rear end to make it work. Patrick & his wife are on a H.D. motorcycle run & un-avaliable this weekend.
#2135 02/02/2003 4:28 AM
Hi MT yes he told me that on Friday. I found an earlier rear end with the Patrick's kit already installed. My question is, should I have only the third member shipped to me and install it to my own axles and torque tube, or should I have more shipped over because it wouldn't simply bolt up to mine.
The thing is, its all in good shape on mine and I want to ship as little as possible.
54 3100 with 235
#2136 02/02/2003 5:42 AM
Tony, what part of the country is the rear end in? Drop me an email. Mike
