| | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#2127 02/01/2003 12:28 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | If I wanted to ship the rear end of my truck do I understand it right that the pumpkin seperates from the rear axle? So, you just ship the pumpkin? Or is it all one assembly? AD 1/2 ton.
54 3100 with 235 62 flatbed dump C60 with 261
#2128 02/01/2003 12:33 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yes, you can remove the axleshafts, disconnect the torque tube, and pull the "third member" and ship it.
#2129 02/01/2003 12:51 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Ok this is the thing. Patricks rear end kit will work on a 54 truck he says but you have to: use the 40-53 differential spool casting #3652336. Otherwise, the installation is exactly the same. That change was done only in 54, so in order to make it work, you need the early differential. So, on my luckiest day I find an earlier differential with the Patricks pinion change already installed but need to have it shipped over here. Am I right to think that all I need to do is swap in that third member for my own to make it work? What about hooking up to my existing torque tube and axles?
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Tony M, Am I correct to assume that since you have a 54 that you cannot simply swap the entire rear drive line "T" (axles, torque tube, etc) ?. If you can, then why not go that direction ? Is it because of the additional freight to ship an intact complete rear driveline ?
Craig
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Yes I figured shipping something that big would cost more and those parts are in really good shape on my own truck. But thinking about it, maybe somewhat broken down it could still all fit on a pallet. I am not sure how long the longest part would be. The extra weight would be negligable on the shipping bill. Size would hurt.
Still hoping to hear from the experts on this forum. But will contact Patrick's again on Monday to get the skinny.
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Tony M, Obviously the torque tube would be the governor as far as dimensions go, but who knows how much an entire driveline weighs ????
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Apparently nobody on this website. I will get my info from Patricks on Monday.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | From what I can gather from Patrick his ring & pinion kit will NOT work on the '54 3:90 rear end & he says you must locate a '47-'53 rear end to make it work. Patrick & his wife are on a H.D. motorcycle run & un-avaliable this weekend. | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Hi MT yes he told me that on Friday. I found an earlier rear end with the Patrick's kit already installed. My question is, should I have only the third member shipped to me and install it to my own axles and torque tube, or should I have more shipped over because it wouldn't simply bolt up to mine.
The thing is, its all in good shape on mine and I want to ship as little as possible. Thanks
| | | | | Joined: Aug 2001 Posts: 139 Member | | Member Joined: Aug 2001 Posts: 139 | Tony, what part of the country is the rear end in? Drop me an email. Mike | | |
