| | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | I am in the process of putting my dash back in my 46 1/2 ton and have replacement chock and throttle cables. I have been looking at the shop manual and am having problems figuring out what to do with the throttle cable, the chock was easy it was hooked up when I removed the dash but no the other. Is the cable needed? and where on the carb does it connect. Thanks in advance, I feel a bit on the dumb side asking this question.
Ed | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I'm not sure of your application but I think it's similar to my 38. On my 38 the cable houseing attaches to the same bracket the choke attaches to. On my 38 the choke is horizontal and the throttle is vertical. Once the housing is attached to the bracket, the wire runs down through a hole (about 3.8" diameter) in the linkage. A wire stop goes on the end of the wire to keep it from pulling back through the hole. If your bracket & linkage are complete it should be fairly obvious.
| | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | Thanks Tiny, I will take a look tonight.
Ed | | |
