6 members (Tstan7, Gone, Napco Mark, ShopRag, Mike Roache, Hanks custodian), 79 guests, and 4 robots.
Topics128,022
Posts1,055,353
Members48,420
#213197 08/07/2006 2:45 PM
I am in the process of putting my dash back in my 46 1/2 ton and have replacement chock and throttle cables. I have been looking at the shop manual and am having problems figuring out what to do with the throttle cable, the chock was easy it was hooked up when I removed the dash but no the other. Is the cable needed? and where on the carb does it connect.
Thanks in advance, I feel a bit on the dumb side asking this question.
Ed
#213198 08/07/2006 3:36 PM
Ex Hall Monitor
Ex Hall Monitor
I'm not sure of your application but I think it's similar to my 38. On my 38 the cable houseing attaches to the same bracket the choke attaches to. On my 38 the choke is horizontal and the throttle is vertical. Once the housing is attached to the bracket, the wire runs down through a hole (about 3.8" diameter) in the linkage. A wire stop goes on the end of the wire to keep it from pulling back through the hole. If your bracket & linkage are complete it should be fairly obvious.
#213199 08/07/2006 4:23 PM
Thanks Tiny, I will take a look tonight.
Ed
