2 members (mo2cyl, Rusty Heaps),
59
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 113 | Okay guys,
I've found information on Art Deco and Advanced Design trucks, but not for the Task Force body style.
I have a '57 GMC that I'd like to replace the dash in. I have a '59 Chev cab that is more than willing to donate the dash to go into the '57 (GM cab is in much better shape, but all instrumentation has been removed. I had to evict the bird and nest from the middle of the instrument panel!).
Is the dash in this truck spot welded, screwed or rivetted in place? Can I easily remove the GM dash and swap in the Chev one?
I'm not afraid of radical surgery, but would like to do this the easiest way!
Any information would be greatly appreciated.
Photo | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | spot welded .... never easy .... involves the windshield pinch weld and braces welded underneath that are critical for mounting/positioning the steering column - need to drill out every weld on both trucks and hope the GMC cab shape and Chev dash shape are a close match but it can be done!! Bill | | | | | Joined: Aug 2005 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 113 | Red58,
Would you have any idea how many spot welds were talking about?
Should I look for 20-25 welds, or 50-60?
Thanks again,
Photo | | | | | Joined: Jun 2006 Posts: 110 Member | | Member Joined: Jun 2006 Posts: 110 | Photo:
I've pulled a couple of these butchered 55 - 59 dashes out over the years. Put a GMC in my 58 Chevy when I was stationed in DC years ago. All spot welds and not a whole lot of them if I remember right. They are pretty easy to see after you pull the trim. I just looked for the little circles and moved the light back and forth until they showed up. I used a couple of old screwdrivers to wedge the dash as I drilled the welds out. They flexing of the metal helped the spot welds show up too. The first one I used a regular bit and it wandered too much, so I ordered a special spot weld bit from Eastwood I think. The second one I used a piloted bit (Dewalt, home depot) had better luck and it left more metal to weld to if the welds line up between trucks. To reinstall I clamped it all up with vise grips and then plug welded with my mig welder. If my mind still serves- the trim under the windshield covers those welds and the windlace covers the ones on the sides. Good luck with your project! Jim
Jim
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there's about 20 on the one pictured - random spacing - no robot welders in them days! in fact I've thought more than once when looking at welds, they let apprentices practice in hidden areas Bill | | | | | Joined: Aug 2005 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 113 | Thanks Guys!
That's the kind of information that I was looking for.
And Stovebolters come to the rescue once again!
Another reason that we all love this page so much!
Photo | | |
