2 members (Oswald, Wayne67vert), 107 guests, and 2 robots.
Topics128,060
Posts1,055,839
Members48,427
#212983 08/04/2006 3:57 PM
my condenser is leaking. would like to replace myself if possible. the system is from southern rods (old aire) and just any generic condenser would do. any ideas or suggestions? or anyone in dallas you could recommend?
#212984 08/04/2006 4:25 PM
Troy -
Why not just take it out and take it to a local A/C service place and have them repair it. If it is "made for the system", it seems it would better to use it than buy a new one, not to mention cheaper.
Joe smile
#212985 08/04/2006 4:40 PM
is a condenser repairable? it looks like it got poked and is "cone'd" out about an inch... seems like there should be some quick way to fix it though...
#212986 08/04/2006 4:48 PM
go to HD and get some of that expoxy puddy/clay, I use it on a lot of things, gets hard as a rock and easy to use, just pinch off what little you need, roll it round and bingo put it on...........I fix a leaking gas tank on my international with gas still in it,,,,,,,,,about 7 yrs ago.. still holding
if you can see the bad spot and can get to it, you may not even need to remove it........ the large tube is about 7 bucks.... called ep-400 epoxy putty..always have some around my place
Redryder pix
My Hotrod
#212987 08/04/2006 5:14 PM
will give that a shot joker. thanks for the tip
#212988 08/04/2006 5:38 PM
Old Air in Ft Worth has a condensor kit engineered for 60-66 trucks,,made for 134A & comes with a drier & lines,,about $200+ but fits like a glove,,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#212989 08/04/2006 5:52 PM
thanks 64fleetside... but a little more than i want to spen at this time. southernrods.com has the condenser i need for $89 and i think old air is the manufacturer??? from what i have found condensers are pretty generic. i tried looking for an auto ac supply to maybe just find a universal condenser. that should work if the fittings are the right size... seen universals on ebay for $50 but think i may try the expxy route first as funds will be limited untill next weekend. with no insulation in the cab and the texas heat i want to get something going ASAP
#212990 08/04/2006 9:09 PM
they also have universal fit condensors listed by size & fitting orientation,,brian
#212991 08/05/2006 4:59 AM
That better be some good epoxy, you are looking at over 200 psi when its hot out! Joe
#212992 08/06/2006 5:15 AM
Troy, there is a really good a/c shop located right off Greenville Ave right next to that old schlumberger lumberyard. I.e. a couple of blocks south of Mockingbird. I don't remember the exact name of the shop, but I have been going to that cat for years. See what he can do for you. I think the stree is Yale. McSomething automotive.
#212993 08/07/2006 3:21 PM
yeah... i decided against that epoxy. arnswine, i'll have to look for that place. thats actually north of mocking bird but i know where you are talking about and yes the name of that road is Yale. i'll see what i can find searching google in that area. whoo! it is too hot around here to not have it fixed!
#212994 08/07/2006 3:50 PM
Would it happen to be:
M Steinberg Co Heating and AC???
#212995 08/08/2006 7:36 AM
Your right on Yale's location, one of my nightclubs used to be there. Just several doors down was Bill Stokes Studio and they did the actual filming of Bonnie and Clyde, even though it was released by MGM or Paramont or one of the big outfits. They fenced off a vacant lot at Yale and Greenville to keep many of the old cars used in the film. Needless to say the bar business got neglected alot while the owner was all over the old cars and probably wore some of the owners out with questions.
Evan
#212996 08/08/2006 4:52 PM
wow... interesting info there coilover. I just watched that movie not to long ago. forgot what an all star lineup it had...
well any leads on what the exact name of that show is and/or a phone number would be extremely helpfull... im dying here guys.
#212997 08/08/2006 11:40 PM
Being the pack rat that I am (would you believe TWO extra storage buildings) I'm sure I have some old Mark 1V or other aftermarket condensers. They're small enough to fit in front of nearly any radiator and that can be a problem. Everything was R-12 when these were in use and their size and fin count isn't what's needed to get the most out of 134A. In the small volume of a pickup cab, especially if insulated, one might do OK. I'll look tomorrow and if ones there it's yours for the gas money it'll take you to come get it. Remember these old condensers didn't have O ring or flare fittings, the hose just fit on a barbed tube and was held with an a/c hose clamp.
Evan
#212998 08/09/2006 12:54 AM
Tab Offline
I'd try soldering it and if that doesn't work, a trip to the junk yard should.
delete my account and pictures
#212999 08/09/2006 4:59 PM
ok. well i found a place by TI at 635 and 75 here in Dallas. McCains A/C service. they sold me a condenser and made the new hoses for me. they even let me install iit in their parking lot and lent me a few tools. great guys and now im COOL! if you need any work in the DFW area check these guys out!
