2 members (Leo, GRNHydra),
84
Mod | | | Forums66 Topics128,060 Posts1,055,837 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | my condenser is leaking. would like to replace myself if possible. the system is from southern rods (old aire) and just any generic condenser would do. any ideas or suggestions? or anyone in dallas you could recommend? | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Troy - Why not just take it out and take it to a local A/C service place and have them repair it. If it is "made for the system", it seems it would better to use it than buy a new one, not to mention cheaper. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | is a condenser repairable? it looks like it got poked and is "cone'd" out about an inch... seems like there should be some quick way to fix it though... | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | go to HD and get some of that expoxy puddy/clay, I use it on a lot of things, gets hard as a rock and easy to use, just pinch off what little you need, roll it round and bingo put it on...........I fix a leaking gas tank on my international with gas still in it,,,,,,,,,about 7 yrs ago.. still holding
if you can see the bad spot and can get to it, you may not even need to remove it........ the large tube is about 7 bucks.... called ep-400 epoxy putty..always have some around my place Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | will give that a shot joker. thanks for the tip | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Old Air in Ft Worth has a condensor kit engineered for 60-66 trucks,,made for 134A & comes with a drier & lines,,about $200+ but fits like a glove,,brian | | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | thanks 64fleetside... but a little more than i want to spen at this time. southernrods.com has the condenser i need for $89 and i think old air is the manufacturer??? from what i have found condensers are pretty generic. i tried looking for an auto ac supply to maybe just find a universal condenser. that should work if the fittings are the right size... seen universals on ebay for $50 but think i may try the expxy route first as funds will be limited untill next weekend. with no insulation in the cab and the texas heat i want to get something going ASAP | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | they also have universal fit condensors listed by size & fitting orientation,,brian | | | | | Joined: Feb 2000 Posts: 5,205 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,205 | That better be some good epoxy, you are looking at over 200 psi when its hot out! Joe | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Troy, there is a really good a/c shop located right off Greenville Ave right next to that old schlumberger lumberyard. I.e. a couple of blocks south of Mockingbird. I don't remember the exact name of the shop, but I have been going to that cat for years. See what he can do for you. I think the stree is Yale. McSomething automotive. | | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | yeah... i decided against that epoxy. arnswine, i'll have to look for that place. thats actually north of mocking bird but i know where you are talking about and yes the name of that road is Yale. i'll see what i can find searching google in that area. whoo! it is too hot around here to not have it fixed! | | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | Would it happen to be: M Steinberg Co Heating and AC??? | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Your right on Yale's location, one of my nightclubs used to be there. Just several doors down was Bill Stokes Studio and they did the actual filming of Bonnie and Clyde, even though it was released by MGM or Paramont or one of the big outfits. They fenced off a vacant lot at Yale and Greenville to keep many of the old cars used in the film. Needless to say the bar business got neglected alot while the owner was all over the old cars and probably wore some of the owners out with questions.
Evan
| | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | wow... interesting info there coilover. I just watched that movie not to long ago. forgot what an all star lineup it had...
well any leads on what the exact name of that show is and/or a phone number would be extremely helpfull... im dying here guys. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Being the pack rat that I am (would you believe TWO extra storage buildings) I'm sure I have some old Mark 1V or other aftermarket condensers. They're small enough to fit in front of nearly any radiator and that can be a problem. Everything was R-12 when these were in use and their size and fin count isn't what's needed to get the most out of 134A. In the small volume of a pickup cab, especially if insulated, one might do OK. I'll look tomorrow and if ones there it's yours for the gas money it'll take you to come get it. Remember these old condensers didn't have O ring or flare fittings, the hose just fit on a barbed tube and was held with an a/c hose clamp.
Evan
| | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | I'd try soldering it and if that doesn't work, a trip to the junk yard should.
delete my account and pictures
| | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | ok. well i found a place by TI at 635 and 75 here in Dallas. McCains A/C service. they sold me a condenser and made the new hoses for me. they even let me install iit in their parking lot and lent me a few tools. great guys and now im COOL! if you need any work in the DFW area check these guys out! | | |
