4 members (Phak1, dt235sd, NorCal52Suburban, Wayne67vert), 85 guests, and 1 robot.
Topics128,049
Posts1,055,546
Members48,425
#212661 07/29/2006 2:58 AM
Mechanic told me the flexplate will not bolt up to the torque converter on my setup. 1984 292, TH350 (1975 I think.) Flexplate is the correct part number,. according to the Advance Auto Parts wbsite and special order I got. Any suggestions?
Thanks for any help,
jay
Your lack of preparation is not my emergency
#212662 07/29/2006 5:40 AM
Most late model flex plates are dual pattern.... this exact problem just bite me, pulled the transmission for nothing. I had tried to use the wrong set of holes.
By the way does your 292 have power steering?
If so could you take a few pictures of how the ps pump is mounted to the engine and email them to me.
#212663 07/29/2006 9:11 PM
I don't have ps. Sorry. Try www.inliners.org
They've got everything..
jay
#212664 07/30/2006 5:41 PM
I have a Hollander parts interchange manual, the Hollander number for a GMC truck,292, A-T TH400, is #469 1980-89. For the TH350 use Hollander #391. The 230/250 uses the same flywheel as the V-8's. Chevrolet trucks will be the same. Joe
