1 members (Donf),
102
Mod | | | Forums66 Topics128,026 Posts1,055,405 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | Mechanic told me the flexplate will not bolt up to the torque converter on my setup. 1984 292, TH350 (1975 I think.) Flexplate is the correct part number,. according to the Advance Auto Parts wbsite and special order I got. Any suggestions?
Thanks for any help,
jay
Your lack of preparation is not my emergency
| | | | | Joined: Dec 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 128 | Most late model flex plates are dual pattern.... this exact problem just bite me, pulled the transmission for nothing. I had tried to use the wrong set of holes.
By the way does your 292 have power steering?
If so could you take a few pictures of how the ps pump is mounted to the engine and email them to me. | | | | | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | I don't have ps. Sorry. Try www.inliners.org They've got everything.. jay
| | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | I have a Hollander parts interchange manual, the Hollander number for a GMC truck,292, A-T TH400, is #469 1980-89. For the TH350 use Hollander #391. The 230/250 uses the same flywheel as the V-8's. Chevrolet trucks will be the same. Joe | | |
