| | | Forums66 Topics128,022 Posts1,055,382 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21232 10/19/2002 1:11 AM | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Just something I've pondered for awhile. When you install a late model drivetrain in an old truck, what do you do with that crossmember that the original bellhousing attaches to? Do you leave it there and mount the new engine/tranny above it? Do you build a lower crossmember to replace it? Or is it safe to just remove it after installing new engine and transmission mounting crossmembers? TIA. Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
#21233 10/19/2002 1:54 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Tony M, you should offically record this as the SECOND question! | | |
#21234 10/20/2002 2:16 AM | Joined: Jul 2002 Posts: 17 Member | | Member Joined: Jul 2002 Posts: 17 | It has been my experience most people, (including me on my '53) Install a new transmission crossmember and remove the old one. I will be reinforcing the frame with channel and will not need the strenth at the bell housing. Exhaust clearance is an issue for most. Ed | | |
#21235 10/22/2002 1:06 AM | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Thanks Ed-that's all I wanted to know. Regards, Wannabe
