7 members (GMCJammer51, Youngin' Tut 59, Tim Canfield, jmoore, 3B, 2 invisible), 111 guests, and 1 robot.
Topics128,196
Posts1,057,385
Members48,469
Would this be a direct swap? Are the springs different? (heavier?)
Thanks!!!
Are you talking the front axle assembly?
Yes
It should bolt right in smile
Y
Y Offline
The complete front axle spring assembly should be the same BUT the Drag Links are different between the 47-52 and the 53-55 1st series. The 47-52 use the type with the tapered tube ends that have springs inside with ball cups and threaded end plugs. The 53-55 1st type uses the late model tie rod end style. This style uses a threaded stud permanently installed within the cast drag link arm.
Hope this helps.
"I always win." Working mainly alone I do not let my trucks win a war. Maybe a battle here and there but never the war.
Robert
55.1 GMC 450 COE
51ish GMC Suburban
I knew that the links switched, but didn't know when.
Overall, the front end assy. is the same measurments?
Russntustin,
My web/ftp site has been offline for several days and I was unable to post this picture from a 1954 Chevrolet Truck Shop Manual. It shows the old style tie-rod ends for 1/2 ton trucks in '54. GMC might have been different. As stated above, most aftermarket replacements are the new-style, with screw on ends.
Tim
[img]http://home.nycap.rr.com/lederman/images/tierod.jpg[/img]
Here is a little background on the tie rod ends:
http://www.classictruckshop.com/t2.asp
Thanks alot!
I didn't know all that! The link was helpful too. wink
Tim,
My repair manual has that same picture of the two different tie end rods but I can't read it as well due to accumulation of oily finger prints over the past few years. wink
Craig
