| | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | | Anonymous Unregistered | | Anonymous Unregistered | I was able to complete the installation of the bear claw latches last Sunday and took plenty of pictures to document my efforts should someone else want to try this themselves. Hopefully this can get turned into a tech tip soon. Once I figured out how to do it on the passenger side, the driver's side went very smoothly. The latches work great and are a great improvement over the old ones. Probably one of the best mods I could make to this truck other than planting a V8 into it. http://www.picturetrail.com/gallery/view?p=999&gid=11601864&uid=2902753 | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i was ready to congratulate you until you mentioned the v/8, heresy. oh well, looks good, congrats anyway. Ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Sep 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 310 | That's the way to do it, figure it out, try it out and then tell the Bolt about it in a Tech Tip A Job well done. Thank YOU | | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Excellent job. Great documentation. I'll be doing that one of these days and your pics will help a bunch. Thanks, Bob  | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Thank you for posting those pictures. I've been trying to decide whether to jump into converting my latches now, before I paint everything, or waiting so I can get the truck finished and drive it. I'm convinced now that I should do it before painting. I found some kits on e-bay for what seem to be reasonable prices- $50 for two latches, strikers and the weld in install kits. http://cgi.ebay.com/ebaymotors/Larg...Z018QQcategoryZ33696QQrdZ1QQcmdZViewItem
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | NM51 - those are the large latches which will not work in these doors. I ordered those first thinking bigger was better but upon further examination found they would not work - just not enough room. Those are the people I got mine from so contact them and ask for the small latches and installation kit. Good luck. | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | I installed the large bear claws in my 50, they work great and were a piece of cake to install. Just have to offset the mounting plate on the door about a 1\2" so the latch clears the run channel. Hooked up the solenoids and remote. "POP" open they come. Also added a linear actuator to the cowl vent and wired it to the remote control with limit switches, push the button and it goes up and stops, push another button and it goes down and stops. Anyway large will work. | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I googled bear claw and found another site where someone installed the reinforcing plates on the inside of the door rather than cutting it out and welding them in place. Here's the other article: http://www.roddingroundtable.com/tech/articles/bearclaw1.html Does anyone have any experiece with 'power bear claws' or installing separate actuators? [img] http://www.a1electric.com/images8/94000.jpg[/img]
| | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | I installed actuators in my 50, simular to the one on the left. Real easy to do, but running the huge 10 ga wire was the hardest part. Mine are ran by a 7 channel remote. ( no door handles in the outside ) | | |
