7 members (Peggy M, cmayna, 49choptop, baldeagle, fonz8261, FrankenChevy, 1 invisible), 59 guests, and 4 robots.
Topics128,018
Posts1,055,341
Members48,419
#211580 07/11/2006 9:15 PM
My truck has the warning light temp guage. In the morning the cold light is on when I start it. The light began to work intermitently and then died. I cleaned the contacts on my temp sending unit and coated them with dielectric grease and hooked everything back up. The cold light worked on occasion and it has went out again. The bulb is good, I pulled it out and looked this last time. My question is this a bad sending unit (the contacts were almost beyond help) or do I need to swap out the contacts in the plug because they are corroded too? And how do I get the contacts out of the plug with out breaking it into pieces? Thanks in advance,
Drew
#211581 07/11/2006 9:26 PM
The problem is. "your truck is too new" grin
#211582 07/11/2006 9:56 PM
Riding in the Passing Lane
If you ground the wire at the sender the light should come on. Same with the hot side. If so replce the sending unit. I like to replace it every time I get a vehicle with a hot warning light. There is no easy way to tell if the hot side is working untill it,s to late. To remove the wire from the holder put a tiny screwdriver in the front of the term. where there is a small recess. It should pull out.
1972 Chevy c10 Cheyenne Super
#211583 07/13/2006 3:21 PM
According to the owners manual, all of the warning lights should be on when cranking the engine. You probably have a bad sending unit. They should be easy to find, and are easy to install.
#211584 07/13/2006 6:49 PM
In my 61 I have a temp gauge, and then an oil and generator light. When I start the truck both the oil and generator lights come on for a couple seconds. They then fade out as the the generator sppols up and the oil pressure climbs. I would imagine that is the same way that the temp light in your truck should work. I had to change the sending unit for my temp gauge to work, it didn't work at all until I did that. Good luck with the old truck!
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#211585 07/14/2006 9:08 PM
I bought a new sending unit at my FLAPS. I'm getting my grandpaw to help me install it tonight and check on some other little issues that have popped up. When I crank the engine, the H, C, GEN, and OIL lights all come on. Once the engine starts, the H and GEN go out first, and once the oil pressure gets up, the OIL goes out. The C goes out once the engine is up to operating temperature. Now neither the H or C come on at all, hopefully that $13 will fix it. I'll let ya'll know if that fixes it.
Drew
