| | | Forums66 Topics128,113 Posts1,056,616 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 24 Junior Member | | Junior Member Joined: Mar 2006 Posts: 24 | its definatly the starter, no bones about it. ive got a 350 block (between 75-81 im not sure) and an 350THM transmission. so basically my question is a two parter... 1 being how many teeth are on my flywheel (i think its 168 but i heard it could be 150 something) and 2 being what kind of starter should i buy, keep in mind im on a tight budget and its a daily drive. id appreciate ANY advice. | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Don't know how many teeth but if money is an issue take the starter to a starter/alternator shop for rebuilding. Usualy 25.00 to 30.00.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you might take the starter with you when and if you exchange it,,,,,,,,,,,,,sometimes what you think you have you dont.......and usually they are several to select from even if you have the correct yr of truck.. just my 2 cents Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | If the armature isn't shot you can put new brushes and bushings in yourself for about $10. I think about all the small block with automatic tranny take the same starter. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I,m with Todd. You can o-haul those youself. Take the cap off the selenoid &clean it up. If the copper term. is worn down loosen the nut & turn it around & use the good side. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | There's almost always a rebuilt stock heavy-duty starter available from your auto parts store - particularly for the Chevy 350. | | |
