1 members (Otto Skorzeny),
181
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,934 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 32 New Guy | | New Guy Joined: Jul 2005 Posts: 32 | Folks, I rebuilt my carburetor this past weekend and noticed that the fuel line fitting thread inside the carburetor was cross threaded. I thought that using teflon would stop a leak from occuring, but unfortunately, I noticed that there is a slow leak dripping out. The carb is an old rochester 4jet with what looks like a 3/4" fuel fitting line. Here are some pics of the carb pre-rebuild: http://homepage.mac.com/spider/truck/carb/carb.html Any ideas on how to stop the leak or fix the thread? | | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | The type of repair depends on the type of thread.
For a straight thread (with a gasket seal), install a helicoil of the proper thread.
For a tapered (pipe) thread, tap to a larger size, and fabricate an insert plug with a flange and a gasket. Tap the insert for the pipe thread. Install the insert with a couple of drops of red loctite on the insert threads. Let set for 24 hours and then install the original fitting in the insert.
I used to make the comment that only plumbers would use teflon, until my father (who has done a LOT of plumbing) informed me that no competent plumber would ever consider the stuff.
The only really GOOD use for teflon tape is to put on stakes you put by newly planted trees. The teflon tape flutters in the breeze, and the individual using the lawnmower does not mow down the trees! (MOO)
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | I have had luck with this method. Try starting the fitting backwards and keeping it as straight as possible. At some point you will feel it kind of like catch a tread. Then when you feel that try to screw it in, if you get lucky it will catch one of the original threads and start straight.
Good luck, Wilbur | | | | | Joined: Jul 2005 Posts: 32 New Guy | | New Guy Joined: Jul 2005 Posts: 32 | Wilbur,
I tried that initially and thought it would work, but the thread is pretty much gone now.
Jon, it is a straight thread with gasket seal, so I'll try finding the helicoil, but most of the local parts stores don't have anything bigger than 1/2".
Teflon does have its uses and have had some luck in other situations. I like your teflon garden decorating idea too; didn't think of that before! | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I think Summit and some other hot rod outfits sell a repair fitting just for that. It cuts its own threads and is a little oversized to get a good fit. I can't promise they have it for a 4-jet,but I've bought 'em for Hollleys before,so there's a good chance they have 'em for others.. Speed | | | | | Joined: Jul 2005 Posts: 32 New Guy | | New Guy Joined: Jul 2005 Posts: 32 | Thanks for all the advice. I haven't been able to locate the right helicoil around here, so I'll keep checking.
In the meantime, I used a ugly but effective solution: liquid teflon. By the time it cured, it looks like the leak is gone. That's enough to get me thru the next couple of weeks. | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | jb weld a nipple in then use rubber fule line worked good on my boat | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Most part stores make a self threading coupler that will screw into the filter housing and clean the threads as you install it. I would suggest that you do not install the filter and install and inline filter, that way you will never have to remove the housing again. The self taping couplers sometimes wont seal the second time you remove them.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Uh??? Did you install the sealing ring on the housing?
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | Agree with 32-Fire. It's hard to beat that good ol' gas-proof J-B Weld. | | | | | Joined: Jul 2005 Posts: 32 New Guy | | New Guy Joined: Jul 2005 Posts: 32 | Guys,
Thanks for all the input.
Toyvo, yes, the sealing ring is there; the thread is definitely stripped.
Given the lack of decent parts stores around here, I may have to go with the JB weld route. | | |
