0 members (),
132
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 111 | I have a 55 1st series Chevy that has 6 lug lock ring (they are not split rings) wheels that I want to replace. Is the 6 lug pattern the same on all Chevy wheels or are the later 6 lugs different from the old ones? I guess the question is, up to what year model can I go and still have the same 6 lug pattern if I am looking for used wheels. THANKS!! Mitchell
54 Chevy 5 window - 46 Chevy 1/2 ton
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Chevy kept the same six lug pattern. The big thing you need to check is the back spacing. To check that lay a straightedge across the back of the wheel (not the tire) and measure to the mounting face. Check that to be sure the wheels and tires will clear fenders, tie rod ends and such.
The last few years they have made some changes with the center setup, and I am told the bolt pattern fits, but the aluminum wheels won't bolt up properly to the older trucks.
Fred 52 3600 69 C-10
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The bolt pattern is the same, however '88 and up have a different backspace due to the indepedent front suspension. They did that to center the alignment angles to the wheel for handling. For the older trucks, you should be able to use wheels from a '87 or earlier 4x4 without any problems. Watch out on aftermarket wheels that are 6 lug, some of them are for Japanese trucks, they have a different backspace and will rub.
Bill Burmeister | | | | | Joined: Nov 2001 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 111 | Thanks, that is exactly what I needed to know. slowgoer
| | | | | Joined: Jan 2002 Posts: 38 New Guy | | New Guy Joined: Jan 2002 Posts: 38 | what is the bolt pattern diameter for the chevy 6 bolt wheel?
"So many trucks, so little time!"
Vehicle list: down to 2 now. 1 - 1967 Chevy 3/4 ton LWB 4x4 2 - do I dare say it??? a 61 Ford Unibody | | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Another thing to consider is that the later model trucks had larger lug stud. Make sure if use a later wheel that your lug nuts are the proper size to secure the wheel. | | |
