8 members (Bill Hanlon, Jon G, 55shaker, Otto Skorzeny, HandyAndy, UtahYork, DadsFirstPickup, Hotrod Lincoln), 78 guests, and 3 robots.
Topics128,036
Posts1,055,448
Members48,422
#210864 06/29/2006 10:00 PM
I have a 55 1st series Chevy that has 6 lug lock ring (they are not split rings) wheels that I want to replace. Is the 6 lug pattern the same on all Chevy wheels or are the later 6 lugs different from the old ones? I guess the question is, up to what year model can I go and still have the same 6 lug pattern if I am looking for used wheels. THANKS!! Mitchell
54 Chevy 5 window - 46 Chevy 1/2 ton
#210865 06/29/2006 11:15 PM
Chevy kept the same six lug pattern. The big thing you need to check is the back spacing. To check that lay a straightedge across the back of the wheel (not the tire) and measure to the mounting face. Check that to be sure the wheels and tires will clear fenders, tie rod ends and such.
The last few years they have made some changes with the center setup, and I am told the bolt pattern fits, but the aluminum wheels won't bolt up properly to the older trucks.
Fred
52 3600
69 C-10
#210866 06/30/2006 12:16 AM
The bolt pattern is the same, however '88 and up have a different backspace due to the indepedent front suspension. They did that to center the alignment angles to the wheel for handling. For the older trucks, you should be able to use wheels from a '87 or earlier 4x4 without any problems. Watch out on aftermarket wheels that are 6 lug, some of them are for Japanese trucks, they have a different backspace and will rub.
Bill Burmeister
#210867 06/30/2006 4:03 AM
Thanks, that is exactly what I needed to know. slowgoer
#210868 11/08/2006 4:58 AM
what is the bolt pattern diameter for the chevy 6 bolt wheel?
"So many trucks, so little time!"
Vehicle list:
down to 2 now.
1 - 1967 Chevy 3/4 ton LWB 4x4
2 - do I dare say it??? a 61 Ford Unibody
#210869 11/08/2006 7:24 PM
6 X 5.5
Bill Schickling
1940 1/2 ton, 1940 3/4 ton
My web page
#210870 11/08/2006 8:54 PM
Another thing to consider is that the later model trucks had larger lug stud. Make sure if use a later wheel that your lug nuts are the proper size to secure the wheel.
