| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | So I've got the 2.5" wide rear leaf springs removed from my 1958 1 ton. I am removing rust and sanding them flat. I intend to lightly paint them before installation. My question is regarding the leaf spring liners that are sold (i.e. Chevy Duty has some).
The liner is only available in 2" wide, but I've got 2.5" wide leafs. Will this 1/2" of surface not in contact with the liner be a problem? There will be 20" less surface area contact between the two leaves with the 2" liner.
Anybody know of a 2.5" liner available? Any suggestions on an alternative liner?
Or should I sand them flat and put em back in the way they came from the factory? They survived bout 50 years and 100,000 miles that a way and will survive a few more the same way.
Thoughts? Suggestions? Thanks! | | | | | Joined: Feb 2000 Posts: 5,194 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,194 | | | | | | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | Thanks Joe!
The 3 3/4" will work. I'll have some trimming to do, but that should be no problem. | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Have you called your nearest spring/suspension shop, they may stock stuff that the vendors don't usually carry.
