| | | Forums66 Topics128,156 Posts1,056,871 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 21 Apprentice | | Apprentice Joined: Feb 2006 Posts: 21 | I have a 53 Chevy 1 ton with a Grain Bed with a Later model Chevy 292 motor and need some information about the year of the engine and the original color it was painted. I think it is between 1968 and 1988, because the dipstick is located near the back on the block. The numbers I have gotten from the block near the dipstick are CON 2 2137 and 3851659 with GM under it and 6 under the GM. Also the numbers stamped into the distributor pad are F21872 and a 21 in a circle. Also need to find out what carburetor was originally on 292 or how to identify the carb on it. It is a Rochester and has an H stamped on the tag. I don’t think this is original carb and it needs rebuilt. I have a big rebuild job on my hands and since I am retired and on a fixed income I am trying to do most of the work myself. This will not be a complete restoration as the truck is fairly solid for being 53 years old. Thanks in advance for any suggestions, they are greatly appreciated. I will try to post some pictures and keep you informed of my progress. Thanks again, Ralph | | |
