3 members (Gdads51, 68ironhead, Peggy M), 94 guests, and 2 robots.
Topics128,118
Posts1,056,302
Members48,439
51 3/4 chevy (straight axle)I know there are power steering upgrades featuring the saginaw out of a late modle chevy truck.What I need to know is what year truck to scavenge the steering box from. Brothers sells all the parts needed and you can save a few bucks if you want to scare up your own steering box but they only say that a box out of a LATE modle chevy truck is needed...NO YEAR. If anyone knows what years apply I would be gratefull...THANKS
do a search as this was recent
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=004057#000000
Jim & Caroline
Before you order that kit make sure you know for sure if it will work on a 3/4-ton.
Generally the kits use a '73 to '87 1/2-ton box, but get the details from Brothers before you order the kit.
Big Peep,
You can do several things to gain power steeing on a solid-axle truck.
1) Use the oiginal GM-type PS - No change to steeing column. To see what that looks like, have a look at:
http://chevy.tocmp.com/1955truck2shop/55ctsm0914.htm
You can purchase one of these as a kit. See:
http://www.classicperform.com/power1.html
OR:
http://www.classictruckshop.com/t1_page4.asp
Note: You can fab one up for youself using C-2/C-3 Covette parts if you don't want to spend that much. That's what I did.
2) Use a kit with a Saginaw PS unit. Sits way forward, you have to move the shocks, and you have to do something about the steering column. Have a look at:
http://www.classicperform.com/tech_articles/Power-Steering-Trucks/Power-Steering-Trucks.htm
3) Use a reverse-rotation Dodge PS box located thru-the-fame close to firewall. See:
http://www.partsamerica.com/Product...amp;ptset=A&sourcepage=SEARCHRESULTS
NOTE: THERE ARE BOTH ROTATION-TYPE BOXES AVAILABLE FOR THE DODGE TRUCKS - HAS TO BE REVERSE-ROTATION.
In this swap, the steering column has to be changed or redone as well.
Good Luck!
As they say in boston...(YOU GUYS ARE WICKED HELPFULL) Seriously...thanks for the help gents.
