4 members (Shardean, Peggy M, klhansen, Eisenholtz), 50 guests, and 5 robots.
Topics128,022
Posts1,055,376
Members48,420
#210437 06/23/2006 9:30 AM
Just bought a '49 1/2 ton Chevy pickup. It came with 16" split rims. I want to replace these rims with one-piece rims. Are there any I can get that will look close to the original and will accept my stock hub caps? Thanks.
http://www.leonmack.com/
'48 Chevy 1/2 ton
'66 Volvo 122S 2-door
'68 Volvo 220
#210438 06/23/2006 2:02 PM
Depends on what they look like. Can you post a picture or two?
#210439 06/23/2006 4:25 PM
As tcleterman says, it depends upon what they look like.
I believe that the wheels through the fifties will fit okay on the front; if the wheels are too wide you'll run into problems. The rear wheels can be whatever you want.
As for "new" wheels... Good luck. AFAIK, the only "new" wheels in production that will fit correctly are the "Bling-Bling" chrome wheels that will definitely look out of place on a '49 1/2 ton and won't accept your hub caps.
Any particular reason that you're ditching your split rims? I'm running the stock 15" split rims on Number Seven and they're working beautifully.
#210440 06/23/2006 7:35 PM
I've actually no experience with old split rims. Just heard they could be dangerous and was thinking that avoiding the innertube might be more convenient. I'm going to use the truck for pulling a single-axle boat trailer 10-20 times a year. The boat ramp is only about 10 miles from my house. Thanks for all your help. [img]http://www.leonmack.com/Chevy3100/P6220118.jpg[/img]
'48 Chevy 1/2 ton
'68 Volvo 220
